JohnDeereJimOhio
I have a straight 350 dozer that I have not used in three months. We decided to sell the dozer and I had someone come look at it this morning. The dozer would not start and I am looking for some advice. The dozer is a straight 350 with reverser on the dash. It has a rebuilt injection pump with less that 200 hours on it. The last time I used the dozer was in mid october and I used it for three hours. Since that time it has been sitting in my barn and has not been ran moved or anything. The dozer has a mechanical shut off on the fuel pump. I got my book out and checked the troubleshooting section. I went through all of those processes. I bleed all the injectors as good as I could by myself. I pulled intake hose off and used some ether sprayed directly in the intake. The batter was not spinning the dozer as fast as normal so I hooked up a booster and still am getting no fire. It will smoke a little wight smoke. I have never had an issue with this dozer starting. We have had some cold weather recently and it has sat a decent amount of time. Does anyone have any suggestions on what to check or do?
I have also moved all shifting reverser and throttle linkages incase that was causing it. I could not fine a neutral safety wire that I saw in other posts.
