2630 throttle
dick1234
Location
Atkins, Iowa
MY 2630 hand throttle: when running engine wide open will, without any warning, go down to about half (tach don't work) throttle. Throttle is still in wide open position. I have, 50/50 mix on diesel, changed fuel filter,and cleaned air filter. Still does same thing. I'm thinking something is going on with injector pump. What do you guys think? Any suggestions are appreciated. Thanks in advance:<) Dick
I'm still kinda wondering if your return fitting is clogging ,,remover the timing cover on the pump and start it up, see if it makes a difference on the RPM's,, a little fuel will leak out but not too much to let it run...
