Plumbing 46A Loader on a 3010
bigfatricky
New User
Hello All,
I am going to mount a 46A loader on my 3010. 3010 has single outlet that I would like to keep open. Where is the best spot to tap into to bring power to the control levers and where is the best place to return fluid?
Thanks for your ideas.
I put a Tee in the supply line to the rockshaft, and a hose to the closed center loader valve. Then a stainless steel line to a drilled hole in the hydraulic filter cover for the return.
Tee into rockshaft return line or ported filter cover.
Tee into line in front of brake pedals for pressure.
Thanks for the info, that sure is appreciated.
One question on the valve: I know it needs to be 2 spool, closed center, no relief, but how many GPM does it need to be?
Can anyone give me a link to something appropriate that I can find on the web?
thanks again,
erik
