John Deere GP cutoffs
Looking to buy cutoffs for my 1931 GP standard. I am not really concerned about the correctness of the wheels (as part numbers go) I just want to make sure the wheels will fit. So my question is, were the any differences in the front spindles or the rear bolt pattern? Thanks.
As far as GP rear cut offs the early wheel and later wheel hub are same bolt pattern. You can also use the AR cut offs just a different back spacing in the hub. I have even seen AC WC rears on them. Pretty sure on the fronts GP and D are the same spindle its the outside dia. of the wheel thats different. If Im wrong someone will correct?
The AC round spokes or the IH round spokes for the rear will fit, but you will need to file the bolt holes a little to make them fit correctly. IH round spokes will fit on the front with a little work also.
Nice looking tractor. What is the width of the rear rim and tire size? The wheels I am looking at are 28". Not sure of the width. They are factory GP steel cut down.
