JD3020 lights
wz766
New User
I have a problem with my lights and need some help in troubeshooting. When the switch is turned on the outside right lamp comes on at the first stop. At the second click the outside right stays on and the other three light very dim with only a slight glow. This does the same for all the rest turns of the switch. Does this seem like a switch issue or something else? The lamps are all good as I checked them on a battery separately and all work. Thanks for any help.
On a different color good old tractor, I had the similar issue, in my case the ground was back through all the old rusty old frame joints. Eliminated that, ran separeate green ground wires, voila', fixed, very bright lights now.
(quoted from post at 10:16:51 12/28/14) You know what I want to tell him....but I don't want to rile the 24 volter's up ;^)
I agree with you that if the tractor in question isn't going to be a "restored,trailer queen" I'd recommend to change it from 24 volts to 12 volts in a heartbeat. :wink:
