Leaking injector question
How to disconnect and repair a leaking injector in a 3 cylinder diesel engine made in Manheim Germany. I have little experience with this and want to acquire some knowledge before attempting the repair myself.
I would appreciate comments from anyone with experience with this task.
Thank You
Ron Corkum
There is no injector in any "manifold." Direct-injected 3 cylinder Deere has a pencil injector that fits in a small bore in the cylinder head and goes directly into the combustion chamber. If it is leaking fuel - either the injector is bad, line is bad, or the connection is loose. No gasket inside that joint. Just metal against metal.
