lloyd in sc
Needing 12v internally ballasted coil for 1010 I am changing to NEG Ground fully 12v ignition system. Who has them & where to go? Thanks.
(quoted from post at 11:50:31 12/23/14) Just for the fun of it.
An external ballast resistor is nothing more than extra turns of wire for resistance to lower voltage to the points. A 12v - no external ballast required coil has those extra turns of wire inside the can. Just out of curiosity, if the extra wire is moved from the outside to the inside why can't it be called internally ballasted?
perhaps if we keep trying we can educate the non engineers and non electricians and those who are electrically challenged about ignition coils and ballast resistors, I have tried for 15 years and will keep on trying to help them.
May God Bless you and yours this Christmas and I'm sure the help you provide is appreciated.
John T Too long retired Electrical Engineer and a bit rusty but I still do my best to help
