I've been trying to get the rock shaft working on my '49 A. I got a lot of help from Pete in MD to just get my pto pump working and now that it does...
First, it had one dummy plug and one hose coupler, and once I found that it wouldn't work that way, I bought another (actually two) dummy plugs. The picture will show what was there to begin with. Note that there is what looks like a ball bearing in the end of the dummy plug. The two that I bought are exactly the same but with no ball bearing. Using one with ball bearing and one without will let me raise the rock shaft, but not let it down. Using the two with no ball bearing does nothing. Which ones should be in there?
Thank you.
Thank you.
