Patrick Potter
Some of you may remember sometime back I replaced seals kit in the main hydraulic pump (on front of engine) since I did this at low idle especially the pump makes a lot of it noise sounds almost like a rod knocking in a engine I can idle it up a little and it will almost completely go away, is this normal especially for something this old.
Note: when I replaced the new seals I did have the thrust fixed on it but I did not make any other adjustments on the pump nor change any of the valve settings I put it back in and went to using it.
