My '49 A serial # is 622982. I only have the operators manual for the number group previous to mine, which tractors had the three position light switch. My switch has just on and off. I'm trying to find out how this system charges, with just the two way switch... or do I have the wrong switch?
Also, regardless of what system I have, how can I get a reading to find if the generator is charging? My amp meter does not work at this time, or simply doesn't show a reading because the generator is not putting juice through the system. All wiring appears to be correct.
Thanks.
Thanks.
