John Deere H power lift cylinder disassembly
CaptainH
I would appreciate hearing how to get an H hydraulic cylinder apart for rebuilding. I have looked at my parts book but I just don't get it I guess. Thanks
Going from memory here, it's been a while. Look for the bolt at the rod end (left in the picture)and back it out. The end will come off with the outer sleeve. Then you can unscrew the cylinder end. Make sure the little ball and spring in the piston are working when you put it back together
