This message is a reply to an archived post by mb58 on May 22, 2013 at 06:23:17.
The original subject was "JD 50 starter mystery".
Hello I was wanting to see if you ever found the culprit. I'm redoing a B and I've got the same issue. Starter works with jumper cable on post but when I put the switch on get nothing. I know it's making contact. Thanks if you can reply just curious. I've tried two switches I had neither works.
Neven
Neven
