Job for you Tim S
Mitch D
Hey Tim we need the steering valve resealed on our 3020 and was wondering if you would be interested in doing it for us? History of it is every once and a while it would steer hard but then come out of it, then one morning it stopped going right and that was the end. Dad pulled it out and we put the rebuild kit in it and borrowed the tool for adjusting the valves from a local former mechanic. Put it back in and same thing. Out, readjust, in, same problem, out, adjust, in, don't work. Guy we borrowed tool from said must have internal crack so we got a new to us from a salvage yard. It had a couple drips from under the steering wheel and first but it went away. Steers great but now there is a stream running out under the wheel hence this post. Not that we can't do it but well you have a test stand and the 3020 has a cab...
My email should be open
Okay Send it to me and I will go through it,,If you only do one once and a while they can give you trouble,,practice helps a lot...
My thoughts too....rarely do they have a crack in them,, but it's possible,,hitting some thing solid with a front wheel can send a "shock" of high pressure back from the steer motor...
