4320 Hyd oil cooler
approximately how many PSI is there at the oil cooler on a 4320? I'm working on a project in the shop and have a oil cooler off a tractor laying there and curious if it will withstand 200 PSI. I know the pressure is 2250 but i'm not sure what it would be on the return side. Thanks in advance.
It will probably handle 200psi, but 100 or less actually flows tthrough it, the oil going through it is return oil dumping to sump..
