I have listened to what all had to say and still got no hydraulics all over my tractor,ive put in a new clutch transfer pump under cab,and new drive gear and shaft to drive it too,made sure no valves were sticking in clutch valve housing,and yes theres fluid being sent back into rear housing and not stored in front,pump is working right,
I was at first going to change the rear hydraulic pump or at least check it but too many said it was a waste of time,but what else could be losing the hydraulics all over this tractor?does anyone here know what else to look for in the center hinge area while ive got tractor turned all the way to the right or is there any other test to try?i am getting fluid back to the rear sump too,and rep[laced all of the small orings when I pulled the clutch housing off,no valves are sticking either.reason I had to pull it was to replace drive gear cause of a worn keyway area on shaft and gear as well,thanks,any ideas?
what is the chance it might be the rear pump?
