I dont know history of tractor was in bad shape when I got it.Have been working on it about a year off and on.I have engine together but cant get it started.Carb rebuilt by a professonal mag is hot new wires blue spark and in time Valves set at .020 by the book pistons are .045 oversize 4 1/2 inch pistons Compression comes up to around 30psi and leaks back through crankcase.But am only hand cranking.It wil almost take off sometimes but never been very promising.Should this air leak back I know with engine cold the compression will be lower.I miced the block before putting pistons in but only at the top read 4.5+.045 with very little ring grove.I have put air in plug holes with both valves closed and air comes back through crankcase but my air pressure is about 120psi.Is my block more wore than I thought or is this normal for blowback on these engines cold.Please help me Im ignorant and stump at what to do.This hand crank and no prize has gotten old.Thanks for your help anyone.
