Not sure what is going on but I'm restoring a 48 B that's never
ran. I changed the cork seal on the flywheel side and cleaned
up the spacer. Put it all together and the crank turns fine until I
put the flywheel back on. The flywheel has the nub that
engages the slot in the spacer and as I try to tighten it up it
gets almost impossible to turn the flywheel. Is it because of the
new cork seal( did soak it in oil ) and it just takes time or is it
something else going on.
