PTO 6886c air pump
jd36a
Was wondering what the screw on the bottom of the pump next to the air hose attachment is for. Someone said chains were attached to it to keep it from turning. If that is correct what were the chains attached to on the tractor? Want to get it back to original as possible so what grade chain and approximately how long was the air hose and the chains. Thanks
There was a spring on the end of the chain, as I recall. We wrapped the chain around the axle and stretched the spring to hold the pump in place.
Don't remember the length of the chain or hose.
I have an old brochure that's not very clear, but here are some of the photos. Other pictures show about 10' of hose, maybe more. I understand that the air fitting that goes on the tire is very rare.
