Best pencil injectors value
Paul_IN
Dad and I are working on a 1969 4020 that misses on a couple cylinders and has plenty of white smoke. Pulled injectors today, two are older and four are newer. The two older ones crack at about 2500 psi, the four new ones crack around 3200 psi. Spray pattern and chatter isn't great on some of the newer ones either. Obviously bad news to have that kind of variation in injectors.
Checked compression and its about 300 psi in cylinders 1 and 2 at 10 hits and 350 psi in the rest at 10 hits. Applied oil to cylinder 2 and that brought up the compression so the engine is obviously worn some. Haven't located our copies of the IT or the JD service manuals yet so am not sure if 350 psi at cranking speed is considered overly low.
Want to try a new set of injectors before any further engine teardown/repair since it for sure needs new ones.
Where do you guys like to go for a good quality, good value injector? I'm not all about low price, I'm happy to pay more for quality but don't want to overpay either. We are close to Indianapolis, IN so have access to diesel repair shops and of course JD dealer and whatever is on the net.
Whatever you do, when you get ready to install the new injectors have them pressure checked just like you did your old ones. I have had new ones be bad right out of the box. Check the pressures and get them as close as possible as well. Mike
I've been using new Chinese pencil injectors
for years with zero problems. In my Case and
Deere tractors. I think you'd have to be nuts
to buy OEM Stanadyne in Deere boxes, or so-
called "rebuilt."
They sell them here on this Website so I'm not
going to mention other places to buy.
Compression test is supposed to be done at 200
RPM. At that speed - ought to be 300 PSI in a
good Dubuque Deere diesel engine. Not 100%
sure with your Waterloo -and my books aren't
here. 425 PSI I think buy I don't trust my
memory with such things.
I'm glad to hear the low cost parts have been working for you. This gives me confidence to go that route.
Paul,
If you don't mind my asking, in general where are you located?
I grew up 4 miles northeast of what used to be Fishers.
Stan
I worked for Stoops there in Indy for around 8 years in parts.
Most injectors nowadays are electronic, the older ones for like a CAT 3406B we sent to Young & Sons there on McCarty.
Always got good service.
You might give them a call & see if they can help you.
