2840 hydraulic part #'s needed
MNfarmer
First off I know the 2840 is everyone's least liked tractor, I get that, hopefully we can bypass all the hate posts. Anyways.... I'm looking for the part number for the kit to plumb a loader into the hydraulics on the side of the transmission. Also was there a part number for the fitting on the SCV valve to plumb a 3/4 line to the filter cover? Thank you for the help.
Since when, or where, is the 2840 a "hated tractor?"
We had several customers who had them and we had no more problems with them as with any other Dubuque twin-stick tractor with a 300 series engine.
We has cold starting issues with ALL new 40 series tractors but those were later fixed by Deere with upgrades.
jdemaris- what were the upgrades? I have a 2840 that don't want to start when it is cool much less when it is cold. I am thinking a block heater?.
MNfarmer
Two simple things you can do to help slow starting is install/use a hyd pump destroking screw(parts key 6) and relocate battery ground cable from battery box to starter mounting bolt.
Parts key 4 AW16707 Union Fitting - UNION FITTING, UNION FITTING ADD 38.31 USD
parts key 6 C19280 Adapter Fitting - ADAPTER ADD 8.06 USD
We assume that the loader's joystick will be supplied from a dedicated fitting on the high pressure line. T'd in just prior to the scv supply? And the loader oil will return via a dedicated ported transmission oil filter ?
Here is a gold mine of info that good old Mother Deere publishes for free on her web site.
http://jdpc.deere.com/jdpc/servlet/com.deere.u90490.partscatalog.view.servlets.HomePageServlet_Alt
R27175 DRAIN PLUG
T31170 COVER
L31052 SCREW
R394R O-RING
L31051 COMPRESSION SPRING
24H1227 WASHER 17/32" X 13/16" X 0.060"
AL25554 FILTER ELEMENT
R34733 WASHER
When at the dealership pickup one of these thingamajigs. They can make a world of difference with winter starting. Works better than the old steering wheel jiggle and it doesn't make the driver look foolish flailing away on the steering wheel.
AR33249 Screw
When the 40 series first came out new - Deere tried several things to improve cold starting including yanking the heads off and changing the valve-head-depth, injection pump timing, thinner head gaskets, etc. Ends up the big fix was new pistons with a higher top piston-ring groove. All the new replacement parts when rebuilding the engine automatically upgrade it.
Cranking speed is of course important also - but wasn't a problem with new ag tractors. When they do develop slow cranking issues - and premature starter failures - a pump destroker is the easy fix.
(quoted from post at 17:30:36 11/24/14) Here is a gold mine of info that good old Mother Deere publishes for free on her web site.
AR33249 Screw
If it were my tractor I use hyd filter AR75603 in lieu of AL 25554 at less than 1/2 the cost.
AL25554 Filter Element - Filter Element ADD 19.03
AR75603 Filter Element - ELEMENT,OIL FILTER ADD 8.20 USD
JD doesn't offer AR33249 any longer.
