G high torque starter ??
joshuaj97
New User
s there such a thing as a newer style maybe gear reduction starter to retrofit to my 51 12 volt G original is bad not wanting to put original type slow starter back on or try to cobb one together or is that my only option thanks
A high CCA group 31 battery and not the cheapest group 31 battery. 2/00 cables with the pos chassis return connected direct to a starter mounting bolt.
A properly rebuilt starter.
She will wail over just fine even with gasoline pistons.
Check below with the tractor pullers.
I put a gear reduction starter on my G but is at my brothers, and hard to get to. If I remember right the starter is for a diesel skid loader of some type. The bolt pattern is the same, and rotation is correct, all you need is to wire a starter button into it.
MT 28,40 milmeter gear,10 tooth I think [count yours] counter clockwise rotation. look on ebay and get the one with the soloind on top or to the back.
If the battery is of limited capacity, connection having high resistance and the cables undersized. How is a more powerful starter going to improve starting?
