Wes Wilkens
This pump was removed once previously since it's got an unpainted pump block. I've taken these out before without having to take the radiator loose but this one doesn't have enough clearance for the shaft to come put of the fan drive tube. The previous guy must have cut the sleeve for just his purpose, but even with that it won't come out. I've tried to rotate the tube inside the ventilator pump housing to see if it will move back, but no dice there either - it rotates but won't move rearward.
I just put a new radiator in it last year and am concerned with dinging up the fins with the fan blades if I get rough with it.
Anyone have any ideas on how best to do this?
Thanks,
Wes
Thanks,
Wes
