ok im back from the farm,and to let you friends know the pump is totally brand new but came in pieces because john deere sells them that way,about 2400.00 for all too,i put it on tractor,and nothing is good,still the same trouble,all hydraulics dead in the water,and I talked to tim briefly who was going to look at a couple more things that could be going on,havent heard back from him yet,but in case there is a problem in clutch pto housing,i pulled out 120 gallons of diesel,and removed left tank and found that mine has the hole cutout to see the housing ,but I haven't removed nothing from there yet,the one thing I can look at once I get the housing off is the pump gear which in a way im hoping it has a sheared key way although there is some forward and reverse slack in the drive gear,it may have slack to begin with,but id like to make sure its only gear teeth slack,and so far this is what happens,
with tractor running,i can pull gear lever toward 2 range with no clutch,and it tries to move,and does move a little,but then when I apply clutch,the movement is gone once I put it in gear with the clutch in,and the top u joint drive quits tyrning too,thats what I get so far with this new pump,still no steering,or gears that work,no 3 point,and no raise and lower disc,.thanks for all help you all have tried with this problem,but now im into the next chapter,thanks and send more help friends,thanks
