'41 G
Charles Scott
08-06-2001 18:31:23
In restoring my "G" I am wondering if someone could please tell me what the correct carb and mag would be for the '41 G. There is a DLTX75 on there now and for some reason I don't think it's right. Thanks for the help.
Gman
08-07-2001 20:01:06
 Re: '41 G in reply to Charles Scott, 08-06-2001 18:31:23
Charles on my '41 "G"(10791)I put a styled G carb on it DLTX-51,I have a DLTX-24 for it,but the 51 is a better carb.Most correct police can't see to good anyway especially where the # is they'll never catchit. There isn't but one thing I can think of that sounds as good as a "G" thats a Harley Hog. Later Gman
chucks
08-08-2001 13:52:06
 Re: Re: '41 G in reply to Gman, 08-07-2001 20:01:06
Thanks for the post..you email is screwed up..it won't go straight through to you...anyway, would you be interested to sell me your unused 24. Thanks for the reply.
al
08-06-2001 22:25:25
Make sure you are reading the right spot.Directly opposite the choke lever side there will be about a 1/4 x 3/4 inch flat spot witha the DLTX #.
Some mistake the # on the bottom of the bowl.
Will P
08-06-2001 22:08:01
You should have on it a DLTX-24. Can't tell you what the DLTX-75 is for. The DLTX-24 was also on a small amount of 40 A's.
William
chuck
08-07-2001 17:04:58
 Re: Re: '41 G in reply to Will P, 08-06-2001 22:08:01
Thanks guys...I found out that the DLTX-75 goes on the model 50. The DLTX - 24 is the carb for any "G" from s/n 1001 thru 12999.
Any one have a 24 for sale?
