ArnieinChesterfieldVa
Two questions for you experts here.
1. What's the best way to check to see if you have spark at each cylinder? Is it to screw out the plug, connect into plug wire, hold grounding area against the frame & turn it over while looking for spark to jump?
2. If I appear to have plenty of gas going to one cylinder (shows on plug) but the other cylinder plug is remaining dry, what could cause this?
Thanks,
Arnie
Thanks,
Arnie
