1956 Deere 420U powershaft
Bill420U
I have a powershaft AM2552T that goes on 420 U and H
models. There is no opening into the housing for a plug or
grease zerk. Does that mean no oil is used and that the pto
turns on the bearings requiring no lubrication at all?
I believe the housing is the same as on my 430 U. It hasa plug to add oil between seals. My pjug has a slot like for a flat blade screwdriver to remove it. It should be filled up to bottom of the hole.
