Model H Rear Lift Question
DScott
I am not very familiar with the details of the Model H but I got one lately that has a hydraulic lift on the back. I have not seen one of these before so I am seeking info about it as far as are they unusual and what might one be worth.
That is the lift for the mounted plow attachment. No idea what they are worth ? Maybe see if any are on ebay.
(quoted from post at 15:08:31 11/10/14) That's the lift arm for the H-1 plow. Do you have any of the plow? I can scan the manual if you need one.
Mike, no that's all I got with the tractor. I was guessing it was for a plow as the tractor has wheel weights on one side it apparently was set up to plow.
Thanks for the replies.
I could use that lift arm if you don't need it. When I got mine years ago it had some large home made bracket welded to it. I scrapped it and made my own but it isn't right.
