how to hook up outlet for wagon lights
I thought newer generation tractors came from factory with a 7 terminal socket. I know my 4255 did. Here's the wiring schematic from a 4440
I just mounted one on my 4240. It's easy enough, the plug can be bought a your local auto parts store, Deere sells a small bracket that mounts the plug above the scv or you could make one. I connected the ground wire to the bracket bolt @ the scv, the tail lights and flashers wires I tied in under the front right of the cab. Remove the small panel behind the right hand battery box just under the small cab door to access and spice into the wiring. Use a tester to determine what wires are what and use a "quick splice" or whatever they're called to keep from having to cut or peel back the wire coating. I now have working lights on my baler by doing it this way.
