hillbilly2
The governor on my M stopped working so while I was making sure all the linkages were connected I noticed the governor case was split in three pieces. I pulled the sheet metal/radiator /fan and pulled the governor off. The weights were wedged together on one side of the shaft. The shaft was bent. The governor gear was missing a few teeth. The cam gear is missing about ten teeth.
The rear governer shaft bushing is ruined. How do you remove that and where can I get a new one it is NLA from deere. My other question is what does anybody think may have caused this failure?
Thanks
Thanks
