3 bottom 3 pt. plow
RwEny
I looked at a plow today that I think is newer than the 810. It has a box beam going across the main beans,trip bottoms, and I think high clearance. If I buy it it will need some parts. I would like to determine model no. so I can get a manual.
Thanks Ralph
Parts for all. 810- 813- f-125 are all the same.Ex for board and share size. 1 tail wheel axle inters from the right and the other from the left and tail wheel brace is diff.
I hope this helps. If it has a beam on top and has safety spring trip standards it's probably either an F120 or F125 but could also be an F130 (almost the same as an F120 but with HD trip mechanisms).
Tyler in IL
ID your JD plow
