Hello. Problem with steering. Rebuilt
the steering valve this spring, put back
Together worked couple days, now will
Hardly steer. Oil comes out of bleed
Valve.
Even when tractor off will not steer.
dealer thought steering motor
(Where tie rods hook on)
Said you had to take off
front axle,then a side rail.
Is there an easy way from top.
I don't know how to hold the
frount up,alot of weight. And
If one takes off a rail, would have
to put a. Beam under the oil
Pan and don't want to crack it
Thanks
Valve.
Thanks
