spark plug for 1944 B
I run Autolite 3116 as I believe these plugs have no INTERNAL REASISTOR and my JD's have MAGNETOS with solid core sparkplug wires. I'm sure there are other brands that will do as well........I happen to be satisfied with Autolite 3116
Bob.....
Good choice for tractors using a Magneto Ignition as that plug, like you say, is a NON Resistor much better suited to Magnetos. Its heat range is just a tad hotter then factory I believe but for light duty or parade use nowadays that's favorable.
John T
AC
C88L is recommended in my late B manual. It is also recommended in the Deere service bulletins & I've had excellent results with them on my magneto A that hand cranks @ -30f to move snow.
