pulley removal
bm3501466
What's everybody using these days to pull off big pulleys like number 24. (Electromagnet pulley on 4400 primary countershaft). The end of the shaft for the locknut is way bigger than any puller I've got...
Sorry. Didn't get the photo uploaded
Is the center of it drilled and tapped ? If so you could make a flat bar with holes drilled for bolts and draw them up onto the end of the shaft.
Mike: Thanks Mike. The center of the shaft has threads in it and on the outside.
Looks like there are two threaded holes in the pulley about 6 inches apart. I think I might drill some holes in flat iron and tac a nut to the middle of the iron to thread a bolt for pressure. I'm sure someone has tried to pull one of these things off before.
