Hi, found a diesel 730 ES that has dual hydraulics. tractor pretty wore out from stem to stern but will this dual hyd box fit on my 730 gas that has only single hyd, rockshaft and live pto? What is an attachment like this worth??
The dual valve box, if complete, can be highly coveted. Depends on the crowd. Could be worth $100... and seen advertised for well over $1000.
It should bolt on to your tractor. Make sure to get the lever, too. The seldom seen 2nd quick disconnect would add a lot, too. Most times, the 2nd valve just has two threaded plugs in the outlet ports.
Yes it will bolt right up. You may want to go through it before you install it. The one I did was worn, Can't remember what was the problem, been 37+ years ago and I sold the tractor shortly after.
