John Deere 4020 front fenders. Factory or after market?
Randy G
I just drove by a JD dealer and seen a 4020 with metal front fenders. Were these factory or after market? Does any one have a picture of how they attach to the wide front axle? How much would a set of these set me back dollar wise? I like the look!
They looked to be flat across the top of the tire and go to a 45 degree down the back. Cost and attachment is my main questions.
Thanks!
After market,, we use to sell a year around fender like you described back in the 70's I don't see them much around here now..
To attach them, a hole in the top of the bracket allows it to fit between the washer under the bolt that holds the spindle arm on and the spindle arm itself. A small U clamp holds it to the arm itself. Hope I made that understandable.
Thanks Richard in Bee. It does help.
By the way, did not get your mag 1st part of the month but called after the 20th. A treasure in my hands now! Thank you
Hiniker made them also. I found a set on ebay a few years ago when I had a customer looking for them. K&M makes front fender kits today with plastic/rubber fenders similar to what the mfwd tractors have.
