johndeeregreg
in regards to john t's advice i set the points how
they should be. i tested the voltage at the coil
terminal like you said and there is 5.75 volts
there. it has a delco remy 1115399 coil on it which
when looked up says it is a 6 volt coil.
i forgot to mention in my previous post that i also
have replaced the ballast, and it is wired for full
voltage while cranking.
