5010 dash style
Pete1989
Evening gents,
Just got a 5010 and it appears all original except it has a 20 series black dash, not the 10 series green one.
Did some 5010s have the 20 series dash or has it been swapped?
(quoted from post at 16:33:11 10/29/14) After serial # 7999, Which were 65" models, ( last yr. made ) 5010's used similar dash & instrument panel as 5020's did...
Great, it's a 65. Thanks a lot.
Just a quick follow-up, did the later ones also come with a square intake as opposed to the round ones?
This is the tractor in question
Good chance you've got a engine transplant from a 5020 ; Block casting #'s could tell, R35130 & R43370 were 5010 #'s ; and if you have newer [rubber wedge style] dipstick, block is from a later 5020, ....
