2010 Cooling System
Buster1111
New User
Would like to drain cooling system from gasoline model 2010 1964 model. Can anyone please advise where exactly is the drain plug, my manual does not show the detail of the system.
Thanks very much.
The radiator drain is at the bottom right side of the radiator.
The block drain is about midway up the side of the engine block, on the LH side, either at the base of the waterpump mount, or back a bit farther back at that same level. (IIRC, gas and diesel MAY be a bit different there, I am more familiar with the diesel version.)
