A friend of mine has a 4010 that he occasionally plows with using a JD 3pt 4-bottom plow. I think he says its an F345 hydraulic reset. The problem is the plow will not trip when it hits an obstacle. He just spent over 4k on major transmission repairs and does not want to use the plow anymore until it is operating correctly. What is the proper way to use this plow? Does the hydraulic lever need to be in the float position? With no hydraulic pressure the plow will trip as soon as its in the ground but if you pressurize the cylinders you can't get the pressure back off and it won't trip. No one around here uses them anymore and the guys that did back in the day don't remember anything. :roll: Someone told him there was something on the plow that was bad (can't for the life of me remember what it was called) and he replaced it but that didn't help anything. We are trying to figure out if this is a plow problem, tractor problem, or operator error. No luck yet on a manual but i'm still looking. Any thoughts or instruction? This place is always a big help and has become my go-to resource for lots of stuff. Thanks for any advice.
