1949 JD B Powr-Trol. Right side, there is a lever
that holds a leaf spring attached to two pins
above and below. These pins hold the plug-ins for
the hydraulic hoses (or dummy plugs when not in
use), hold those plugs in... Leakage is at bottom
pin. How to repair - Is it removable from outside,
with some sort of an "O" ring... How to repair?
Leaking pretty heavy almost a stream. doesn't
matter whether tractor running, Powr-Trol running
or not.
or not.
