2020 diesel lift not working, front pump lost prime
SHAHEEN11165
New User
2020 diesel lift not working, front pump lost prime. any good suggestions on where to start checking on why the pump in the trans is having problems supplying hydro fluid to the front pump
Check to be sure frt pump drive shaft is not stripped out and spinning on pump shaft IE pump shaft not turning with engine. How long since hyd filter was changed and sump screen(parts key 30) was checked/cleaned?
thr
the filter was check and appeared to be clean but i have not checked the screen # 30 (did not know about it ) and i will also check front pump shaft . Thank you sir very much It will be a week or so until I get back to the farm so I will be a little while getting back to you . thank you very much
I would replace the filter with a new one. They can be plugged with fine material that you can't see unless you cut it apart. I've seen guys waste a lot of time chasing hyd problems because of a plugged filter.
ok thanks I will round up some 5 gallon buckets and a new filter
right after I make sure the front pump is actually turning with the crankshaft and input shat not sheared or stripped or ...
