dieselfume
Started tearing down the 14,000+houred 404 in our 76 4630.
Figured I'd take the head off first to get it sent out to the machine shop while I did the front cover and cleaned things up and re-assembled.
The valvetrain looked good, when I went to remove the head I had a broken head bolt that's been busted for awhile. it's broke off flush with the block deck and looks pretty rusty. I soaked it down with penetrating oil but I'm not sure how this will work out.
The cyl walls have no crosshatch left, but no visable scoring and a healthy ridge. pistons are all intact and have no cracks.
so far I don't see any cracks on the head except for at the hole where each nozzle protrudes there's about a 1/8-1/4 inch crack running back... no cracks anywhere else that I see right now. I'll know more when I get it completely buffed off.
I'm short the correct deep 15/16 socket to remove the nozzles, so I'll have to get that later, or have the machine shop do it.
I haven't got the radiator pulled or front cover off yet, but I'll try to get at that tomorrow.
My questions are-
How should I best go at this broken head bolt?
my instinct tells me to try and weld a nut on it, but I've never had one break off on the block deck before.
How do I "pin" this engine on TDC for valve adjustment purposes, and how do I correctly re-time the crank/cam/IP once the front cover is apart?
What are the specs for head bolt torque, and should the head bolts be replaced? what about valve lash specs?
Anything else I should be looking at before I order more parts?
I'll pull the lifters tomorrow to make sure the cam and lifters are good. didn't have time today.
Thanks!
DF
My questions are-
Thanks!
DF
