JD 4430 turning problem
lemroy
On my 4430 it will turn real short to the right, however it doesn't turn short to the left. How do you correct this. Roy
Is this a new tractor to you?? Or is it some thing that has happen on it's own here recently??
I WAS TOLD BY A JD mech that this could be taken care of by adjusting the linkage. i will try this. Thanks all you techs. Roy
If "some how" one tie rod got adjusted out of whack and the other one was mated to this miss adjustment, yes,, but this is unlikely,, set your wheels straight, then look to see if your steer arm is centered, if it is then you have motor timing issues...
