Hello JD users & experts:
I am looking at the subject tractor for utility use around my small pecan farm and house (some dirt work for landscaping around house & orchard, lifting super sacks etc. & rototiller use) and would like opinions on the following questions I have on this tractor:
1. According to the current owner the loader (with bucket level) won't go any lower than existing grade. Of the few loaders I can remember using in the past most would go below this 'neutral' position, thus allowing digging below existing grade on level ground. The current owner says once the bucket is tilted it will lift the front end of the tractor off the ground. Questions:
1. Won't this limitation of the loader greatly restrict how effective the loader will be when I want to remove dirt below grade on flat ground? (even though I realize I could tilt the bucket then move forward to remove dirt with the tilted bucket)
2. Is this normal operational range for this JD tractor/loader combination?
3. The current owner has told me that it takes about a minute after the tractor has been started for the loader and 3 pt hydraulics to become fully operational. Does this indicate a symptom of a pending hydraulics repair problem? ( He has told me he has changed the screen for the hydraulics system) located back by the single hydraulics remote in the rear- behind the aluminum looking knob (see attached pic)
4. He wants $6900 for the tractor (1969 year model per tractor data & s/n of tractor)-- comments on fairness of this price?
5. It appears from reading previous posts this model JD is a good choice for what I intend to use if for--any comments on that conclusion?
FYI, I currently have an Oliver 550 I use in my orchard which is just right to get in and around tight spots I have when running an orchard knife for weed control, so that the JD 2020/48loader won't be used for that.
Also from previous posts the diesel version apparently is more fuel efficient and can get more work done, BUT I cannot tolerate the smell of diesel fumes, so want to stick with gas.
Any assistance with these questions would be greatly appreciated!
Kind Regards
d page
sorry for the double pics (couldn't determine how to delete the extra ones!)
Kind Regards
d page
