I found a 620 with farmhand loader and purchased it. It will be a big step up from a 1940 A with someone's homemade copy of a dual loader.
Questions.
1. The clutch engages OK, but doesn't seem to disengage. Can't shift while engine is on, can't seem to stop the belt pulley either.
2. Governor isn't erratic, but doesn't hold back the throttle either. Seems to idle alright if I choke it till it almost stalls??
3. Power steering only works when I turn right, doesn't seem to work at all when turning left.
Suggestions?? I have found that equipment that has sat for a long time sometimes isn't really "boken" just sticking, slipping, needs oil flow etc. Any thoughts (mainly on the governor and clutch, the steering is probably a leaking steering valve).
Thanks,
Questions.
Thanks,
