4020lp rebuild
(reply to post at 19:55:47 10/18/14)
PISTONS, RINGS, AND CONNECTING RODS
(GASOLINE AND LP-GAS)
Cart KEY PART NO. PART NAME QTY ENGINE SERIAL NO. REMARKS
1 R66454 CAP SCREW 12 (SUB FOR R26323 OR R53289)
2 R53291 SLEEVE 12 XXXXXX - (USE WITH ROD MARKED R58879)
3 R30929 BUSHING 6
4 AR86982 CONNECTING ROD 6 (MARKED R26046 OR R44257 OR R58879) (SUB FOR AR26327, AR45498 OR AR70909)
5 AR45723 BEARING 6 (SUB FOR AR27628) (MARKED R26087 OR R44378)
AR46395 BEARING 6 0.05MM (.002") US, (SUB FOR AR27629) (MARKED R28226 OR R44925)
AR46396 BEARING 6 0.25MM (.010") US, (MARKED R44926)
AR46397 BEARING 6 0.50MM (.020") (SUB FOR AR27640) (MARKED R28228 OR R44927)
AR46398 BEARING 1 0.76MM (.030") US, (SUB FOR AR27642) (MARKED R28230 OR R44928)
6 R41707 SNAP RING 12 (SUB FOR R26145)
7 R26088 PISTON PIN 6
R28970 PISTON PIN 6 0.08MM (.003") OS (YELLOW) (NLA)
R28971 PISTON PIN 6 0.13MM (.005") OS (RED)
8 AR34394 PISTON RING 6 (A) (SUB FOR AR33994)
AR45966 PISTON RING 6 (B) (HEAVY-DUTY)
9 AR45964 PISTON 6 (B) 4.21" (WITH RINGS MARKED R33372 OR R34617) (MARKED R33372 OR R34617) (SUB FOR AR39769 OR AR39771)
AR39770 PISTON 6 4.21" (WITH RINGS (LP-GAS) (MARKED R33374 OR R40778) (SUB FOR AR40616)
10 R33197 CYLINDER LINER 6 (A) 4.25" ID X 4.81" OD, (USE WITH R40017, R33170 OR R40880) (ALSO ORDER (6) AR40155) (SUB FOR AR32194)
R40614 CYLINDER LINER 6 (A) 4.25" ID X 4.84" OD, (ALSO ORDER (6) AR70645)
R26118 CYLINDER LINER 6 (A) 4.00" ID X 4.62" OD
11 AR52547 PISTON-LINER KIT 1 (B) (SUB (6) AR40155, (6) AR52549 AND AR53624) (USE WITH R33197)
........ PISTON-LINER KIT NA (LP-GAS) (NOT AVAILABLE)
AR52549 KIT 6 (B) (MARKED R33372)
12 AR40155 O-RING KIT 6 (SET OF 2) (USE WITH R33180, R34340, R40017, R40890 OR R40900) (USE WITH R33197 AND BLOCK MARKED R33170) (USE WITH R33197 AND BLOCK MARKED R40880)
AR70645 O-RING KIT 6 (SET OF 2) (USE WITH R40860, R40930, R40940 OR R49550) (SUB FOR AR48687)
AR65507 O-RING KIT 6 (SET OF 3) (USE WITH R40880 OR R33170)
.. R116253 SHIM AR 0.050MM (.002 IN.)
(A) GASOLINE AND LP-GAS (B) GASOLINE
