Anyone knows partnumber for this hose on 4440
Kollebo
hello
Does anyone knows the part number on the little plastic hose on top of powersteering motor in the front.
Goes from the top of the steering motor and in under the Main hydraulic pump.
I guess its about 30 cm long and 5-7mm thick
Cant find IT in the part catalouge and cant and a photo of IT
Because i dont understand how to?
Tanks Kalle from sweden[/img]
AR56065 I keep them here..
Ok
thank you Tim
what does this hose have for function?
It has rubbed a hole in it against the main pump
an leaks down on the front axle hfwd
thanks
Kalle
It transfers bleed or "leakage" oil from the steer motor to the "Tee" fitting on the main Hydraulic pump, where it goes on to the transmission case through the small plastic hose going up along the right frame rail. They get hard and brittle, and rubs like yours over time, I replace them each time I'm down in there ...It helps to keep up with little leaks that make a mess..
