Radiator drain plug
Where is the radiator drain plug located on a John Deere D (1948)? I have an owners manual and a parts book but no mention of drain plug in either one. Can it be the plug located on top of the bottom tank? I hope not. Thanks, Basil
Those were simple machines... the pipe plug in the bottom of the cylinder head drains the block, and the radiator, as well.
The drain on a D is on the bottom of the block near the middle. The wishbone that hold the front end on sort of hides the plug, you just about have to get on your hands and knee's to look under there to see it, just a pipe plug.
# 41 drains all there is to drain!
