DLTX 99 Carburetor Rebuild
These questions relate to the rubber seals and felt packing for the
choke and throttle shafts:
1.Do the lips on the rubber seals turn in or out? I know on an oil
seal the lip goes toward the oil.
2.Does the rubber seal go inside the felt packing, or outside? Or,
which one goes on first?
3. Do the casting plugs (like little freeze plugs) require any sealer?
They seem a little smaller that the original.
Lips go "in" , Felt on last and who knows who makes this stuff anymore so if it fits a little loose,seal it and spike it.
Not familiar with that exact carb. However if the lip seals are exposed to engine vacuum the lip goes out (away from the vacuum)
Gtx1967jewison is correct. Lip of seal is out, to keep dirt out and vacuum in. Felt goes to the outside of the seal, keeps seal clean. If plugs are like a freeze plug, the dish is out, put a little no.1 permatex on edge. But plugs should if snug to begin with. Tap center of plug to seal in..
