(quoted from post at 14:27:26 10/11/14) You don't use motor oil in the transmission, buy 85/140 it will also help quiet worm gears
(quoted from post at 17:01:52 10/11/14) So, 60 weight engine oil is comparable to 140weight gear oil?
(quoted from post at 19:25:40 10/11/14) I meant to say "worn" gears, I guess
Buick and deere knows more than the
john deere engineers who recommend
80/90 lube for these old tractors, I
don't care what"Bob the oil guy on
the internet"says, motor oil will
not carry on the gears like
transmission oil will, ive seen the
demonstrations on lubrication,your
top shafts and gears are probably
suffering from very little lube.
(quoted from post at 19:58:04 10/11/14) Use whatever you want but I've never
seen 50wt motor oil recommended for
a 50 to 60 year old tractor
transmission, you better call john
deere and let them know "bubba"
(quoted from post at 09:59:09 10/12/14) I ordered GL1 140wt from my local Car Quest.
No one around here can get the straight 50wt or 60wt motor oil.
A bottle of Lucas oil treatment/stabilizer(crs) would toughen up the GL1 and it's yellow metal friendly. Their Hub Oil isn't.
